[QGIS-Developer] Filtering features in a layer by a report group
    Tim Sutton
    tim at kartoza.com
    Tue Aug  6 23:22:40 PDT 2019
Hi All
I am trying to create a section in my report (not layout) which iterates over my plant types lookup table and applies a filter to my vegetation points layer based on the plant type ID.
Ideally I should set my filter of my vegetation layer based on the atlas feature id like this:  "plant_type_id" = attribute(@atlas_feature,id)
Instead I tried to make a rule using the same above expression so that symbols are blank for non matching plant features.
However in my report group, ‘Controlled by report’ is greyed out for my map and so when rendering the report the map comes out as a single blank copy instead of one per plant type.
I suspect this is because report wants to have geometries to zoom to for each record. Other than adding a fake geometry column to my plant type lookup table, is there any way to get reporting to control my map by report when the reporting layer is a non-spatial table?
Side note: QGIS layer filtering is a "poor relation” it is one of the few places in QGIS where a non standard expression editor is used. The other major one was the raster calculator but now at least we have the raster calculator processing algorithm.
BTW using 3.8 on macOS here.
Thanks!
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
I'd love to connect. Here's my calendar link <https://calendly.com/timlinux> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190807/249bcc65/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190807/249bcc65/attachment-0001.jpg>
