[QGIS-Developer] Looking for tips to avoid unnecessary configuration reset when building QGIS
Matthias Kuhn matthias at opengis.ch
Mon Aug 12 23:50:31 PDT 2019
Hi Harrissou,
You can setup ccache, which will cache previously compiled files for you.
Best regards
Matthias
On 8/13/19 7:37 AM, DelazJ wrote:
> Hi devs,
> I'm facing a recurrent issue with the process of building QGIS and I'd
> like to get feedback/advice from you.
> I checkout and build master branch
> Whenever I modify files I can run the build command and it applies
> rather quickly. only the diff is taken.
> Now that I'm satisfied with my changes, I create a new branch, commit
> the changes and push to github
> Locally, I checkout back my master branch (so back to the original
> HEAD - no pull from upstream!)
> I do new changes (for another fix)
> *Issue*: If I run the build command, it looks like it reads again the
> configuration file and instead of building only the diff, it builds
> all, taking too much time. Like if I hadn't already built QGIS.
> So, how do you avoid this unnecessary waste of time?
> Thanks for any advice.
> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190813/bfa55634/attachment.html>
More information about the QGIS-Developer mailing list
