[QGIS-Developer] Looking for tips to avoid unnecessary configuration reset when building QGIS
DelazJ
delazj at gmail.com
Tue Aug 13 01:38:56 PDT 2019
Hi Matthias,
Thanks for answering. You mean
https://htmlpreview.github.io/?https://github.com/qgis/QGIS/blob/master/doc/INSTALL.html#toc7?
I'm pretty sure I did that in the past but I'll give it another shot as
soon as possible.
Regards,
Harrissou
Le mar. 13 août 2019 à 08:50, Matthias Kuhn <matthias at opengis.ch> a écrit :
> Hi Harrissou,
> You can setup ccache, which will cache previously compiled files for you.
> Best regards
> Matthias
> On 8/13/19 7:37 AM, DelazJ wrote:
> Hi devs,
> I'm facing a recurrent issue with the process of building QGIS and I'd
> like to get feedback/advice from you.
> I checkout and build master branch
> Whenever I modify files I can run the build command and it applies rather
> quickly. only the diff is taken.
> Now that I'm satisfied with my changes, I create a new branch, commit the
> changes and push to github
> Locally, I checkout back my master branch (so back to the original HEAD -
> no pull from upstream!)
> I do new changes (for another fix)
> *Issue*: If I run the build command, it looks like it reads again the
> configuration file and instead of building only the diff, it builds all,
> taking too much time. Like if I hadn't already built QGIS.
> So, how do you avoid this unnecessary waste of time?
> Thanks for any advice.
> Harrissou
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190813/611cf2ce/attachment.html>
