[QGIS-Developer] GSoC QGIS 3D Improvement: Week 11 Report
Ismail Sunni
imajimatika at gmail.com
Wed Aug 14 10:56:08 PDT 2019
Hi Nyall,
Thanks for the reply!
More and more your work is revealing that we'll eventually need to
> tackle this issue head on, and implement proper opacity support in the
> 3d renderer. Everything else is going to be just a hack which won't
> work in all circumstances. I'd suggest not spending much more time on
> this issue given this (current) inherent limitation.
Sure.
I looked over your branch, and it seems the issue is in saving and
> restoring the symbol, not the retrieval of the symbol from the button.
> Is that correct?
The billboard changes IF the previous billboard is not a symbol. But IF the
previous billboard is a symbol, and I changed the symbol's properties (e.g.
color, rotation, shape) the billboard stays the same.
In my latest code (pushed by now), I set the billboard to use an external
image (the success-kid.png) if the symbol's color is white (for debugging
purpose).
If I set the symbol to white, the billboard uses the success-kid as the
billboard (no matter what is the previous billboard as expected).
If the previous symbol is the* success-kid, *then I changed the symbol's
properties it will change as expected.
If the previous symbol is not the *success-kid*, then I changed the
symbol's properties, it won't change the billboard.
When I close QGIS and reopen it, the billboard will show as expected. So, I
think it's not an issue in saving and restoring the symbol.
Previously, I thought the problem is the changed signal from the button or
the saving and restoring, but it seems it is something else.
Best regards.
On Wed, Aug 14, 2019 at 1:18 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Mon, 12 Aug 2019 at 06:54, Ismail Sunni <imajimatika at gmail.com> wrote:
> > Dear QGIS developers,
> > Here is my 11th-week report for my GSoC Project[4]. You can also check
> the project wiki page [2]. Comments and suggestions are welcome :)
> > GSoC QGIS 3D Improvement Week 11 Report
> > Period: 5 August 2019 - 11 August 2019
> > Report
> > 1. What did I complete this week?
> > - Fixing transparency for the billboard to make it smoother on the
> edge. It looks better than the previous result, but still not as smooth as
> I expected
> > 2. What am I going to achieve for next week?
> > - Solve using a symbol from QgsSymbolButton
> Is that correct?
> Nyall
Ismail Sunni
ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190814/0dc826bb/attachment.html>
