[QGIS-Developer] GSoC QGIS 3D Improvement: Week 12 Report
Ismail Sunni imajimatika at gmail.com
Mon Aug 19 00:51:53 PDT 2019
Hi Luca Manganelli,
Niiice!
Thanks!
In the video I see a circle that is cut in half, it is right?
Yes, it seems so. I am not sure either since sometimes it happens sometimes
it's not. I also opened the same project with QGIS 3.8.1, it shows the same
thing. Perhaps the problem is already there (not related to the feature
that I develop) or the project that I have. I haven't checked further. See:
https://imgur.com/a/cisqkiX
Best regards.
On Mon, Aug 19, 2019 at 8:20 AM Luca Manganelli <
luca.manganelli at comune.trento.it> wrote:
> Niiice!
> Il giorno dom 18 ago 2019 alle ore 21:01 Ismail Sunni <
> imajimatika at gmail.com> ha scritto:
>> Dear QGIS developers,
>> Here is my 12th-week report for my GSoC Project[4]. You can also check
>> the project wiki page [2]. Comments and suggestions are welcome :)
>> This time, I made a video to show the progress after stuck with a
>> blocking issue.
>> GSoC QGIS 3D Improvement Week 12 Report
>> *Period*: 12 August 2019 - 18 August 2019
>> *Report*
>> 1. What did I complete this week?
>>    - Debug "Changing symbol doesn't always change the billboard"
>>    - Get help from Martin to fix the problem. It's updated because
>> QgsTerrainTextureImage thinks it doesn't need to update the symbol due to
>> the same extent.
>>    - Removing unrelated UI (transformation and material widget) for the
>> billboard
>>    - Add set height option for the height of the billboard
>>    - Save the billboard symbol as a symbol attribute (previously using
>> serialization)
>>    - Add `selected` symbol for the billboard. It's showing a
>> black-symbol, not yellow-symbol like a normal selected one.
>>    - Save the billboard symbol to the project.
>>    - Fix flipped billboard
>>    - Video about this progress: https://youtu.be/QZr16uq8Pco
>> 2. What am I going to achieve for next week?
>>    - Addressing black selected symbol
>>    - Address size symbol issue
>>    - Finalize and submit PR
>>    - Write final report
>> 3. Is there any blocking issue?
>>    - N/A
>> 4. Code
>>    - Branch for billboard feature [1]
>>    - Repo for QT C++ billboard [3]
>> 5. Misc
>>    - N/A
>> ## References
>> - [1] https://github.com/ismailsunni/QGIS/tree/billboard
>> - [2] Project Wiki:
>> https://github.com/ismailsunni/QGIS/wiki/GSoC-2019---QGIS-3D-Improvement
>> - [3] https://github.com/ismailsunni/qt3d-custom-shader
>> - [4] https://github.com/ismailsunni/QGIS/wiki/Week-12-Report
>> Best Regards.
>> Ismail Sunni
>> ismailsunni.wordpress.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Luca Manganelli
> Assistente informatico
> Servizio Innovazione e Sistemi digitali
> Via Ezio Maccani 148
> 38121 Trento (TN)
Ismail Sunni
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190819/3937680e/attachment-0001.html>
More information about the QGIS-Developer mailing list
