[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Loïc Bartoletti lbartoletti at tuxfamily.org
Wed Aug 21 01:11:20 PDT 2019
Hi Rainer,
Le 17/08/2019 à 20:07, Rainer Hurling a écrit :
> Hi Loïc,
> Sorry for the late answer, I had been on vacation for some days.
And it's my turn now ;)
> I tested again on a recent HEAD amd64 (r351113) and it fails with clang
> 8.0.1, but builds with clang 9.0rc2! So this really seems to be a
> special problem of clang and should be solved until 9.0x.
> In the next days, I will prepare the updates for graphics/qgis-ltr and
> graphics/qgis.
Good to know. FYI, there is a plan to bump LLVM_DEFAULT to 90. It may be
worth indicating that llvm80 should not be used.
Best regards,
Loïc
> Best wishes,
> Rainer
> On 10.08.19 10:14, Loïc Bartoletti wrote:
>> Hi Mathias, Hi Rainer,
>> Rainer, I update all ports and I cannot reproduce the issue... Tested on
>> FreeBSD 12 (jail) with clang 8.0.1 and clang 9.0rc1.
>> Do you still have this problem?
>> Best regards.
>> Loïc
>> Le 12/07/2019 à 22:44, Matthias Kuhn a écrit :
>>> Hi Loïc,
>>> Thanks for the feedback.
>>> Any idea what else could be tried?
>>> Unfortunately I do not have a system where I could quickly try, so I
>>> am out of possibilities and ideas for now ...
>>> Best regards
>>> Matthias
>>> On 7/12/19 9:47 PM, lbartoletti wrote:
>>>> Hi Matthias, Rainer,
>>>> Matthias, I tested but unfortunately I can't reproduce the problem
>>>> with this
>>>> code. Tested with llvm 6, 7 and 8 on FreeBSD 12 and 13 amd64.
>>>> But, of course :), the problem is still present for QGIS with llvm
>>>> 8.0.1 on
>>>> FreeBSD 13.
>>>> For information, I created a CI on Cirrus for FreeBSD 12 and here the
>>>> results: https://cirrus-ci.com/task/5576588232491008 and my fork of your
>>>> repository https://github.com/lbartoletti/qmap_initializer_compile_time
>>>> Thanks to take care about this issue.
>>>> Loïc
>>>> Sent from:
>>>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
