[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Rainer Hurling
rhurlin at gwdg.de
Sat Aug 17 11:07:21 PDT 2019
Hi Loïc,
Sorry for the late answer, I had been on vacation for some days.
I tested again on a recent HEAD amd64 (r351113) and it fails with clang
8.0.1, but builds with clang 9.0rc2! So this really seems to be a
special problem of clang and should be solved until 9.0x.
In the next days, I will prepare the updates for graphics/qgis-ltr and
graphics/qgis.
Best wishes,
Rainer
On 10.08.19 10:14, Loïc Bartoletti wrote:
> Hi Mathias, Hi Rainer,
> Rainer, I update all ports and I cannot reproduce the issue... Tested on
> FreeBSD 12 (jail) with clang 8.0.1 and clang 9.0rc1.
> Do you still have this problem?
> Best regards.
> Loïc
> Le 12/07/2019 à 22:44, Matthias Kuhn a écrit :
>> Hi Loïc,
>> Thanks for the feedback.
>> Any idea what else could be tried?
>> Unfortunately I do not have a system where I could quickly try, so I
>> am out of possibilities and ideas for now ...
>> Best regards
>> Matthias
>> On 7/12/19 9:47 PM, lbartoletti wrote:
>>> Hi Matthias, Rainer,
>>> Matthias, I tested but unfortunately I can't reproduce the problem
>>> with this
>>> code. Tested with llvm 6, 7 and 8 on FreeBSD 12 and 13 amd64.
>>> But, of course :), the problem is still present for QGIS with llvm
>>> 8.0.1 on
>>> FreeBSD 13.
>>> For information, I created a CI on Cirrus for FreeBSD 12 and here the
>>> results: https://cirrus-ci.com/task/5576588232491008 and my fork of your
>>> repository https://github.com/lbartoletti/qmap_initializer_compile_time
>>> Thanks to take care about this issue.
>>> Loïc
>>> Sent from:
>>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
