[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Loïc Bartoletti
lbartoletti at tuxfamily.org
Sat Aug 10 01:14:32 PDT 2019
Hi Mathias, Hi Rainer,
Rainer, I update all ports and I cannot reproduce the issue... Tested on
FreeBSD 12 (jail) with clang 8.0.1 and clang 9.0rc1.
Do you still have this problem?
Best regards.
Loïc
Le 12/07/2019 à 22:44, Matthias Kuhn a écrit :
> Hi Loïc,
> Thanks for the feedback.
> Any idea what else could be tried?
> Unfortunately I do not have a system where I could quickly try, so I
> am out of possibilities and ideas for now ...
> Best regards
> Matthias
> On 7/12/19 9:47 PM, lbartoletti wrote:
>> Hi Matthias, Rainer,
>> Matthias, I tested but unfortunately I can't reproduce the problem
>> with this
>> code. Tested with llvm 6, 7 and 8 on FreeBSD 12 and 13 amd64.
>> But, of course :), the problem is still present for QGIS with llvm
>> 8.0.1 on
>> FreeBSD 13.
>> For information, I created a CI on Cirrus for FreeBSD 12 and here the
>> results: https://cirrus-ci.com/task/5576588232491008 and my fork of your
>> repository https://github.com/lbartoletti/qmap_initializer_compile_time
>> Thanks to take care about this issue.
>> Loïc
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
