[QGIS-Developer] Profile plugins
Wilhelm Berg wb at bergwerk-gis.at
Tue Aug 27 01:06:29 PDT 2019
Hi, I'm the developer of the VoGIS Profile Tool.
I understand the goal of unifying and it makes total sense to reduce
redundancy, but this plugin was contract work for the Austrian province
Vorarlberg (
https://vorarlberg.at/web/land-vorarlberg/-/landesamt-fuer-vermessung-und-geoinformation-lvg)
tailored to their needs (eg hectometers)
I have to consult with them about their thoughts first before being able to
provide any suggestions.
Cheers
On Tue, Aug 27, 2019 at 9:22 AM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Dear developers of profile plugins,
> as you know, we do our best to keep the plugin repository tidy and
> clean, to reduce duplication which is confusing for the users and makes
> management and maintenance more difficult. With >1,000 plugins now, this
> is a necessity more than a choice.
> A suggestion from Calvin[0] in the qgis-dev mailing list pushed me to
> approach you again, to check together the opportunities to improve the
> current situation. I would be grateful if you could take the time to
> check his suggestions and discuss together the way to come up with a
> beautiful, unified plugin. I know this is extra work for you, and that
> everybody tends to like his own solutions, but the gains from having an
> unified solutions are great from all points of view.
> Looking forward for your suggestions.
> Cheers.
> [0]
> > I don't consider "Profile Tool" to be perfect, but I find it useful to
> > generate cross sections on DEMS. There are 4 plugins that create
> > profiles, but I would say that "Profile Tool" is the easiest to use. The
> > plugin "Temporal/Spectral Profile Tool" probably should not have been
> > accepted as a QGIS plugin because it is a modified version of the
> > Profile Tool. I can't get it to work. That author should have worked
> > with the Profile Tool author to make a better plugin. VoGIS Profile Tool
> > is also very similar. qProf seems to be a little more advanced.
> > Ultimately, it would be nice to merge all 4 into one tool.
> Paolo Cavallini - www.faunalia.eu
> QGIS.ORG Chair:
> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190827/10448625/attachment.html>
More information about the QGIS-Developer mailing list
