[QGIS-Developer] Travis build timeouts
Alexis R.L.
alroyliz0 at gmail.com
Tue Aug 27 13:38:42 PDT 2019
Could this be linked to the image issues that we had, maybe the image issue
was a symptom of something.
I just find it strange that we have nearly an hour increase in build time.
Would it be a good idea to contact someone at travis to inquire about what
might be the issue?
Alex
Le mar. 27 août 2019 à 02:25, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Tue, 27 Aug 2019 at 16:12, Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
> > It seems that the timeout were done in time to correctly save ccache
> information.
> > It looks like build are a bit faster today.
> > If not, we can try to drop all the caches to start with something clean
> again.
> I did that earlier today -- but I don't think any builds have
> successfully completed since :)
> Nyall
> écrit :
> >> On Tue, 27 Aug 2019 at 06:54, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> >> > Greetings everyone,
> >> > I've been noticing that most builds today timeout, usually building
> and testing take some time but today the build time are far higher than
> some days ago.
> >> > I'm wondering if we should increase the timeout to 3 hours (it
> timeout after around 2:26 hours) or if there is a way to use ccache and
> only compile files that were changed instead of compiling the whole project
> when there is the slightest change.
> >> The builds normally use ccache, but something has broken in the last
> >> week and the cache either isn't being correctly stored or restored
> >> between Travis sessions. Not sure if it's in our setup, or an issue on
> >> Travis itself. (But there's been no related changes in our code, so
> >> I'm pointing the finger at Travis)
> >> Nyall
> >> > With out ever-expanding codebase things don't seem to scale well.
> >> > I just wanted to start an internal discussion between members of the
> project regarding this issue.
> >> > Thanks and have a nice day,
> >> > Alex
> >> > _______________________________________________
> >> > QGIS-Developer mailing list
> >> > QGIS-Developer at lists.osgeo.org
> >> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190827/641f6723/attachment.html>
