[QGIS-Developer] Travis build timeouts
Nyall Dawson
nyall.dawson at gmail.com
Mon Aug 26 23:25:40 PDT 2019
On Tue, 27 Aug 2019 at 16:12, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> It seems that the timeout were done in time to correctly save ccache information.
> It looks like build are a bit faster today.
> If not, we can try to drop all the caches to start with something clean again.
I did that earlier today -- but I don't think any builds have
successfully completed since :)
Nyall
> Le mar. 27 août 2019 à 02:25, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
>> On Tue, 27 Aug 2019 at 06:54, Alexis R.L. <alroyliz0 at gmail.com> wrote:
>> > Greetings everyone,
>> > I've been noticing that most builds today timeout, usually building and testing take some time but today the build time are far higher than some days ago.
>> > I'm wondering if we should increase the timeout to 3 hours (it timeout after around 2:26 hours) or if there is a way to use ccache and only compile files that were changed instead of compiling the whole project when there is the slightest change.
>> The builds normally use ccache, but something has broken in the last
>> week and the cache either isn't being correctly stored or restored
>> between Travis sessions. Not sure if it's in our setup, or an issue on
>> Travis itself. (But there's been no related changes in our code, so
>> I'm pointing the finger at Travis)
>> Nyall
>> > With out ever-expanding codebase things don't seem to scale well.
>> > I just wanted to start an internal discussion between members of the project regarding this issue.
>> > Thanks and have a nice day,
>> > Alex
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
