[QGIS-Developer] Travis build timeouts
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Aug 26 23:12:12 PDT 2019
It seems that the timeout were done in time to correctly save ccache
information.
It looks like build are a bit faster today.
If not, we can try to drop all the caches to start with something clean
again.
Le mar. 27 août 2019 à 02:25, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Tue, 27 Aug 2019 at 06:54, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> > Greetings everyone,
> > I've been noticing that most builds today timeout, usually building and
> testing take some time but today the build time are far higher than some
> days ago.
> > I'm wondering if we should increase the timeout to 3 hours (it timeout
> after around 2:26 hours) or if there is a way to use ccache and only
> compile files that were changed instead of compiling the whole project when
> there is the slightest change.
> The builds normally use ccache, but something has broken in the last
> week and the cache either isn't being correctly stored or restored
> between Travis sessions. Not sure if it's in our setup, or an issue on
> Travis itself. (But there's been no related changes in our code, so
> I'm pointing the finger at Travis)
> Nyall
> > With out ever-expanding codebase things don't seem to scale well.
> > I just wanted to start an internal discussion between members of the
> project regarding this issue.
> > Thanks and have a nice day,
> > Alex
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190827/95bc9868/attachment.html>
