[QGIS-Developer] Travis build timeouts
Nyall Dawson
nyall.dawson at gmail.com
Mon Aug 26 17:25:02 PDT 2019
On Tue, 27 Aug 2019 at 06:54, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> Greetings everyone,
> I've been noticing that most builds today timeout, usually building and testing take some time but today the build time are far higher than some days ago.
> I'm wondering if we should increase the timeout to 3 hours (it timeout after around 2:26 hours) or if there is a way to use ccache and only compile files that were changed instead of compiling the whole project when there is the slightest change.
The builds normally use ccache, but something has broken in the last
week and the cache either isn't being correctly stored or restored
between Travis sessions. Not sure if it's in our setup, or an issue on
Travis itself. (But there's been no related changes in our code, so
I'm pointing the finger at Travis)
Nyall
> With out ever-expanding codebase things don't seem to scale well.
> I just wanted to start an internal discussion between members of the project regarding this issue.
> Thanks and have a nice day,
> Alex
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
