[QGIS-Developer] travis failing with: Error: Microsoft ODBC Driver 17 for SQL Server : Login failed for user 'sa'..
Sandro Santilli
strk at kbt.io
Thu Aug 29 06:47:36 PDT 2019
On Thu, Aug 29, 2019 at 12:35:45PM +0100, Jorge Gustavo Rocha wrote:
> Hi Sandro,
> Maybe I'm missing something, but the Travis failure is not related with
> MS ODBC Driver (which is used by the mssql provider).
> Travis is failing with:
> 507/559 Test #507: PyQgsPostgresProvider .........................***Failed
> https://cdash.orfeo-toolbox.org/viewTest.php?onlyfailed&buildid=14455
Uhm, does it take going to CDash to know what's wrong with a build ?
> That is related to your PR, right?
Yes, PyQgsPostgresProvider was touched by my PR
> Are Postgresql tests running file on your local environment?
When I remove all tests but the one I added, yes, they
run. When running the full tests, they also fail in master
branch for me. How I'm running the test:
ctest -V -R PyQgsPostgresProvider
Example of failures I'm getting:
511: ======================================================================
511: FAIL: testJson (__main__.TestPyQgsPostgresProvider)
511: ----------------------------------------------------------------------
511: Traceback (most recent call last):
511: File "/usr/src/qgis/qgis-master/tests/src/python/test_provider_postgres.py", line 734, in testJson
511: self.assertTrue(vl.isValid())
511: AssertionError: False is not true
511:
511: FAIL: testStyleDatabaseWithService (__main__.TestPyQgsPostgresProvider)
511: Test saving style in DB using a service file.
511: File "/usr/src/qgis/qgis-master/tests/src/python/test_provider_postgres.py", line 1318, in testStyleDatabaseWithService
511: self.assertEqual(len(ids), 1)
511: AssertionError: 0 != 1
511:
PostgreSQL server is version 9.6.9.
> > https://github.com/qgis/QGIS/pull/31468/files
--strk;
