[QGIS-Developer] osgeo4w's qgis-dev package broken, proj_7_0.dll missing
Jürgen E. Fischer
jef at norbit.de
Fri Dec 6 00:01:47 PST 2019
Hi Nyall,
On Fri, 06. Dec 2019 at 09:06:13 +1000, Nyall Dawson wrote:
> > Yes, the rebuild has picked the new proj up.
> > Rhere also a new qgis-ltr now - and new standalones for 3.4.13.
> > As that also required updates to the build scripts in the release branch -
> > tomorrows 3.4.14 should be almost the same - except for some translations…
> Testing 3.4.13, it looks like you've successfully found a solution to
> use gdal < 3 and proj < 6 for the 3.4 build?
> Great work!!
Thanks. GDAL 2 and prøj 5 are now separate packages - prøj 5 being built
statically and shipping with it's own files, although it's actually using the
files from prøj 6 at runtime (as that's where also the grids are) - but those
are identical except for ITRF2005 where +ds=-0.00008 is instead of
+ds=-0.000008 - and I guess that's a fix).
I didn't have time left to test much - spatialite is only there once using prøj
6 and it's used by all GDALs and all QGIS'.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191206/74fa5ee5/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191206/74fa5ee5/attachment.ksh>
