[QGIS-Developer] QGIS packages build against ubuntugis-unstable dependencies
Jürgen E. Fischer
jef at norbit.de
Fri Dec 6 01:24:20 PST 2019
Hi Ben Hur,
On Fri, 06. Dec 2019 at 14:41:27 +0800, Ben Hur Pintor wrote:
> Am I correct in thinking that rebuilding QGIS against the
> ubuntugis-unstable dependencies would solve this issue?
Yes, that would be the last option from the note in the debian/ubuntu section:
The release packages are only produced once shortly after a new version has
been released. As unstable, not yet released debian versions (testing) and
ubuntugis-unstable can have library changes the packages might sooner or later
be broken for these targets, when the development in debian, ubuntu or
ubuntugis-unstable moves on and their packages used as dependencies in qgis
change. In that event you can either
* move to a stable debian version and use the released packages for it,
* wait for the next point release (due 2019-12-06 12:00:00 UTC), which happens
every month and will include the updated dependencies,
* switch to a nightly repository (available for the two release branches and
master) whose packages are rebuild on regular basis and will also pickup the
updated dependencies automatically or
* build your own set of packages (see INSTALL).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191206/d3497289/attachment.sig>
