[QGIS-Developer] QGIS packages build against ubuntugis-unstable dependencies
Ben Hur Pintor
bnhr.dev at gmail.com
Fri Dec 6 12:17:50 PST 2019
Hi Bernd and Jürgen,
Thank you for your replies. I decided to use the nightly repository first
while waiting for the point release.
Sincerely,
Ben Hur
On Fri, Dec 6, 2019 at 5:24 PM Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Ben Hur,
> On Fri, 06. Dec 2019 at 14:41:27 +0800, Ben Hur Pintor wrote:
> > Am I correct in thinking that rebuilding QGIS against the
> > ubuntugis-unstable dependencies would solve this issue?
> Yes, that would be the last option from the note in the debian/ubuntu
> section:
> The release packages are only produced once shortly after a new version has
> been released. As unstable, not yet released debian versions (testing) and
> ubuntugis-unstable can have library changes the packages might sooner or
> later
> be broken for these targets, when the development in debian, ubuntu or
> ubuntugis-unstable moves on and their packages used as dependencies in qgis
> change. In that event you can either
> * move to a stable debian version and use the released packages for it,
> * wait for the next point release (due 2019-12-06 12:00:00 UTC), which
> happens
> every month and will include the updated dependencies,
> * switch to a nightly repository (available for the two release branches
> and
> master) whose packages are rebuild on regular basis and will also pickup
> the
> updated dependencies automatically or
> * build your own set of packages (see INSTALL).
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
*Ben Hur S. Pintor*
bnhr.xyz
hi at bnhr.xyz
open spatial & data solutions
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191207/dd73016b/attachment.html>
