[QGIS-Developer] Find unmaintained plugins
Matthias Kuhn
matthias at opengis.ch
Sun Feb 3 01:17:52 PST 2019
Hi all,
Marking a plugin as "unmaintained" or "deprecated" is a heavy action which may discourage developers and make even useful plugins disappear.
Thus if this is done in any way, I am in favor of sending several reminders to a plugin author over a time period of at least 6 months before taking any action. It then needs to be super easy for a plugin maintainer to remove this status from their plugins.
Maybe alternative approaches could also be considered to move maintained plugins to the top and make stars / votings more relevant. Or have the possibility to flag a plugin as unmaintained (like stackoverflows "needs moderator attention") where it's required to post a link to an issue which has not received an answer in a long time.
There are various variables which need to be balanced in this discussion like losing useful plugins, adding maintenance burden (to plugin developers and plugin maintainers), having a credible plugin ecosystem. Let's make sure we keep all of them in mind.
Thank you
Matthias
On 2/2/19 8:30 AM, Paolo Cavallini wrote:
> Thanks for your offer of help. I agree that the mail should be sent only
> for plugins not updated in the last (3? 6? 9?) months.
> Could you please start filling up a ticket on
> https://issues.qgis.org/issues
> so we can define specs resulting from this thread and start implementing it?
> Cheers.
> On 01/02/19 22:40, Thomas Baumann wrote:
> > Hi Paolo,
> > sounds like a good idea to send a reminder once a year to the maintainer
> > and mark plugins as unmaintained if no feedback is received.
> > I am available to help implementing it.
> > Regards,
> > Thomas
> > Am Fr., 1. Feb. 2019, 19:01 hat Paolo Cavallini <cavallini at faunalia.it
> > <mailto:cavallini at faunalia.it>> geschrieben:
> > Hi Thomas,
> > On 01/02/19 13:53, Thomas Baumann wrote:
> > > I made the experience that there are QGIS-plugins which are not
> > > maintained anymore.
> > > Example:
> > http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-Rectangles-Ovals-Digitizing-plugin-deprecated-td5366686.html
> > > Recently I asked some maintainers if they have plans to update their
> > > plugins to be QGIS3-ready because I was willing to update them if the
> > > maintainer wouldn't do it... but again I got the impression that some
> > > plugins are not maintained anymore.
> > > Example:
> > > https://github.com/NathanW2/selection-sets/issues/5
> > > Now that there is the change from QGIS2 to QGIS3 some unmaintained
> > > plugins will just dissapear like through a "natural selection". But in
> > > one or two years there could again be lots of unmaintained plugins
> > which
> > > could have bugs that slow down qgis or make them unstable like it
> > > happened with the Rectangles-Ovals-Digitizing-plugin (
> > > https://github.com/vinayan/RectOvalDigitPlugin/issues/6 ).
> > > Wouldn't it make sense to check once a year if all plugins are still
> > > maintained?
> > > You could for example use something like LimeSurvey (
> > > https://www.limesurvey.org/community ) and ask every maintainer to
> > > respond if they still feel responsible for the plugin. In the
> > backend of
> > > Limesurvey you have a database with the responses so it should be
> > quite
> > > easy to automatically synchronize the results with your
> > repository-items.
> > > This way the unmaintained plugins could be marked as deprecated if no
> > > response is sent back.
> > thanks a lot for your suggestion. I agree that the move to QGIS 3
> > automatically purges old unmaintained code, but this does not solve
> > entirely the issue.
> > In short do you suggest we should run a survey once a year, sending it
> > to the list of plugin maintainers, and marking as deprecated all plugins
> > for which we do not receive a positive response?
> > I would be a bit skeptical, as many plugins are still useful even if not
> > actively maintained. An alternative would be to add to our Django app an
> > automatic reminder to be sent to maintainer, asking to confirm they
> > maintenance; in absence of a feedback, we could mark it as unmaintained,
> > and make this visible to users, so they have the options of adopting it,
> > supporting it, or stopping using it before it actually stops working.
> > How does it sound? in case you agree on this or a modified version of
> > it, would you be available to help implementing this?
> > All the best.
> > Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu>
> > QGIS.ORG <http://QGIS.ORG> Chair:
> > http://planet.qgis.org/planet/user/28/tag/qgis%20board/
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
