[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Feb 6 06:11:42 PST 2019
Hi Axel,
If you really want to test your plugin in macOS, you can sign up to one of
the cloud based services, which offers you remote access to a macOS
desktop. We use https://www.macincloud.com/ for QGIS macOS builds and their
customer service is very good.
Regards
Saber
On Wed, 6 Feb 2019 at 14:02, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hi,
> I don't think that the supported platforms of a plugin should be a
> limitation for publishing it in the QGIS repository. If it's useful for a
> high number of users, why not?
> To me the only important thing to do, is to inform the users of any OS
> restriction, so that people don't waste time trying to make the plugin work
> in a non supported platform.
> I wonder how many of the published plugins have been tested to confirm
> that they work both on windows, Linux and Mac.
> Best regards,
> Alexandre Neto
> A qua, 6/02/2019, 13:35, Tom Chadwin <tom.chadwin at nnpa.org.uk> escreveu:
>> Matthias Kuhn 🌍 wrote
>> > If it's a single-purpose use-case specific plugin which is
>> > intended to be run inside a specific organization / scenario, then I
>> > don't see the benefit of investing a lot of effort into something that
>> > will never be used.
>> By "effort", do you mean the work to make it cross-platform? If so, yes,
>> but
>> in the case you describe, there is also no argument that the plugin should
>> go in the official repo.
>> This is a specific, but not uncommon, case, if I understand correctly. The
>> QGIS plugin is a kind of middleware between QGIS and another tool which is
>> not cross-platform. At work we have multiple users with another such
>> plugin.
>> In these cases, I guess it's a judgement call: are there enough potential
>> users out there who would benefit from the extra visibility of having this
>> plugin in the QGIS official repo? Or is the plugin so closely tied to the
>> third-party application that it is more appropriate that that other app
>> should host it, either on their own compatible plugin repo, or as a zip
>> (bearing in mind that installing a plugin from a zip is massively easier
>> than it used to be)?
>> At the end of the day, all other factors being taken into account,
>> excluding
>> a plugin because it only works on Windows runs the risk of the project
>> appearing to be unfriendly towards Windows. As a Windows user myself, I'm
>> afraid that attitude is sometimes (often?) apparent among QGIS devs, as it
>> obviously is in the broader open-source dev community.
>> Cross-platform is a QGIS killer strength. But let's not make it a dogma.
>> Thanks (and apologies if this went a tad OT)
>> Tom
>> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190206/a3b29a80/attachment.html>
