[QGIS-Developer] Module not recognized in Python
Paul Riedel ben.jamin at posteo.de
Fri Feb 8 01:54:17 PST 2019
The files are unzipped into \omf\ and they have an __init__.py file in
that folder, it should at least FIND it...
Am 06.02.2019 um 15:34 schrieb Richard Duivenvoorde:
> On 2/6/19 12:04 PM, Paul Riedel wrote:
>> Dear Devs.
>> Kind of a help request here. Usually I would ask in a Discord or some
>> other chat program but there doesn't seem to be one?
>> I am trying to write a plugin to import Open Mining Format data into
>> QGIS(and maybe export it??)
>> Anyway, I went through the process of setting up a new plugin through
>> the Plugin Creator Plugin, went through the hassle of doing the
>> resources on Windows by doing
>> https://gis.stackexchange.com/questions/273552/pyrcc5-is-not-recognized-as-an-internal-or-external-command
>> since OS4Geo-shell doesn't recognize the bin and has no access to the
>> .exe for some reason.
>> So the plugin initializes and shows in QGIS.
>> Now, I copied the OMF library files into my plugin folder so now it
>> contains
>> python\plugins\omf_loader\omf\
>> However, upon trying to import the library by calling "import omf" or
>> "from . import omf" in the "run" Method, I get the error that the
>> library can not be found.
>> This is weird since I had a look at other plugins and they also use
>> local imports for helper functions...
>> Can you provide any help?
> Hi Paul,
> besides the mailinglist there is a irc channel and a gitter channel
> (with a bridge to the irc and vv):
> https://gitter.im/qgis/QGIS
> But indeed this should work, something like
> from .omf.base import UidModel
> maybe?
> Are you sure you have the python files unzipped there?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
