[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Nathan Woodrow
madmanwoo at gmail.com
Mon Feb 11 17:44:15 PST 2019
Personally I don't see any reason to not allow it in official repo and
there is support for that here as IMO there is nothing bad here and nothing
should force people to work 100% on all platforms all the time because that
is a hell of a lot of work that is hard even for skilled developers.
I appreciate everyone trying to work out a method to allow this to run
cross-platform and a avoid a Windows-only solution, and in a perfect world
that is what we all want, but in this case, it won't work out and I think
having it in the official repo is better than not in this case as it allows
for better user experience for the target users.. If we can get it running
cross-platform by adding stuff to QGIS in future so be it and we
can reevaluate at that point but I think we need to support this plugin in
this case as it's not how it is.
Regards,
Nathan
On Tue, Feb 12, 2019 at 11:27 AM <Christina.Ratcliff at csiro.au> wrote:
> Hi All,
> Thank you all for your suggestions and ideas for resolving this issue.
> The use of VESPER is currently not negotiable, and as I’ve previously pointed out, VESPER is a tool of choice for kriging in the Precision Agriculture industry in Australia. We will continue using VESPER as it is currently implemented in the PAT plugin. If hosting PAT on the official QGIS plugin repository cannot be approved, we will host it on our own repository. This would be disappointing as we believe the official plugin repository would provide the greatest visibility to the broader global precision agriculture community.
> Regards,
> *Christina Ratcliff*
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190212/6ffb310d/attachment.html>
