[QGIS-Developer] Import in PostGIS error
Nyall Dawson
nyall.dawson at gmail.com
Mon Feb 11 21:14:09 PST 2019
On Tue, 12 Feb 2019 at 01:36, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi all,
> importing the attached shp into PostGIS results in an error[0]. When
> saving it to a linestring without the Z dimension, The import goes
> smoothly. I suspect this is a bug on our side. Any hint?
> Thanks.
Confirmed, fix at https://github.com/qgis/QGIS/pull/9159
Nyall
> [0]ERROR: TypeM needs 3 dimensions
> CONTESTO: PL/pgSQL function addgeometrycolumn(character
> varying,character varying,character varying,character
> varying,integer,character varying,integer,boolean) line 39 at RAISE
> SQL statement "SELECT AddGeometryColumn('',$1,$2,$3,$4,$5,$6,$7)"
> PL/pgSQL function addgeometrycolumn(character varying,character
> varying,character varying,integer,character varying,integer,boolean)
> line 5 at SQL statement
> Paolo Cavallini - www.faunalia.eu
> QGIS.ORG Chair:
> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
