[QGIS-Developer] How Create regularly spaced, defined # of points within polygon?
Alexandre Neto senhor.neto at gmail.com
Fri Feb 15 00:22:50 PST 2019
You can use the create grid algorithm, which allow a grid of points and
then intersect with the polygons layer:
https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectorcreation.html#create-grid
I haven't tried but it may be possible to use a layer features for extent.
Best regards,
Alexandre Neto
A qui, 14/02/2019, 22:09, Richard Duivenvoorde <rdmailings at duif.net>
escreveu:
> On 2/14/19 4:54 PM, Apoyo Carbono wrote:
> > Hi everybody!
> > I want also to Create regularly spaced, defined # of points within
> > polygon in QGIS, does exist any plugin for this?
> > I could do it with an Arcgis's extension called ET GEOWIZARD (Uniform
> > points in polygons) , but I need to do in QGIS!! Can you help me?
> > Postscript: I'm sorry for my translate to  english. I'm learning it.
> Hi,
> There are probably other ways to (this is the que for other to chime in
> :-) ), but for QGIS 2.x I created a simple plugin which does this: fill
> one or more selected polygons with a grid or diamond shape of points (or
> follow a line and put trenches on it).
> I created it for a customer, so not sure if it fits your plan (there is
> no way to tell the exact number of points for example. But you can find
> it in the plugin manager (of QGIS 2.x only):
> http://plugins.qgis.org/plugins/FeatureGridCreator/
> Docs:
> https://rduivenvoorde.github.io/featuregridcreator/FeatureGridCreator/help/html/en/
> If it is something you could use, let me know, if I find time I'll try
> to create a QGIS3 version for it.
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190215/dc115da8/attachment.html>
More information about the QGIS-Developer mailing list
