[QGIS-Developer] Plugin idea for Editing multiple layers
Alexandre Neto senhor.neto at gmail.com
Sat Feb 16 08:43:36 PST 2019
I believe that both plugins haven't been ported to qgis3, right?
I never tried QAD, I will look at it.
Thanks
A sáb, 16/02/2019, 16:30, Thomas Baumann <rdbath.regiodata at gmail.com>
escreveu:
> Hello Alexandre,
> for editing/selecting multiple layers I have used the QAD Plugin before.
> For just selecting features from multiple layers there is the
> MultipleLayer Selection-plugin:
>  https://plugins.qgis.org/plugins/MultipleLayerSelection/
> I think such a tool is indeed very useful.
> Regards,
> Thomas
> Am Sa., 16. Feb. 2019, 14:54 hat Alexandre Neto <senhor.neto at gmail.com>
> geschrieben:
>> Hi,
>> I don't do much editing, but recently I needed to edit several layers at
>> the same time. Although I find the digitizing capabilities of QGIS great,
>> the bigger bottleneck I found in terms of productivity was in the selecting
>> tools, because it forces the user to first make the layer active before he
>> can select a feature in it. Editing multiple layers at the same time forces
>> you to repeat that over and over again.
>> So I though it would be nice to create a multi layer selection tool. It
>> would work like the identify tool, selecting the first feature from top to
>> bottom, then it would make the respective layer active, therefore ready for
>> editing.
>> Other options could be added later, like selecting the next and previous
>> feature, or selecting all features from all layer. There could be options
>> to determine which layers can be selected.
>> Two questions:
>> - for users: Anyone finds this useful?
>> - for developers: Being done as a python plugin, will this be to slow if
>> one uses too many layers/features?
>> Thanks,
>> Alexandre Neto
>> Alexandre Neto
>> @AlexNetoGeo
>> http://sigsemgrilhetas.wordpress.com
>> http://gisunchained.wordpress.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190216/14059c62/attachment.html>
More information about the QGIS-Developer mailing list
