[QGIS-Developer] Provide a max. legend size in case of map unit sized symbols
Régis Haubourg
regis.haubourg at gmail.com
Tue Feb 19 04:00:42 PST 2019
Hi David,
>From a user point of view, using both desktop and server, I would go to the
second option with a configuration setting.
I think it should apply to all the classes of a layer, as soon as one of
the class symbols reaches max size, just don't scale any of the symbols in
the legend. This way you won't have a wrong legend, with some classes still
being scaled and bigger classes fixed.
Thanks for tackling this, it's a real issue for most users.
Best regards
Régis
Le mar. 19 févr. 2019 à 10:03, David Signer <david at opengis.ch> a écrit :
> Hi there
> I'm struggling with the following issue
> https://issues.qgis.org/issues/21309 summarized like this:
> *When using map units as symbol size and having a max value in mm, this
> value is always taken in the GetLegendGraphics request with QGIS Server,
> what leads to huge symbols there (same in legend of print layout).*
> I think it's not always needed to adapt the exact size to the legend.
> So I see three approaches:
> - Don't adapt the size to the legend at all
> - Provide a configuration "Maximum size for legend"
> - Provide a max size property for the server (does not solve it for print
> composer)
> Where I would prefer the "Maximum size for legend" configuration.
> What do you think?
> Thanks
> Dave
> David Signer
> david at opengis.ch
> +41 (0)78 766 13 03 <+41787661303>
> [image: OPENGIS.ch Logo] <http://www.opengis.ch>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190219/0d3670f2/attachment.html>
