[QGIS-Developer] Provide a max. legend size in case of map unit sized symbols
David Signer
david at opengis.ch
Wed Feb 20 03:50:13 PST 2019
Hi Nyall
I think, you're right. If there's no max size defined (enabled) on the GetLegendGraphics, it responds with memory error (so possibly because the size gets infinite because of zero scale).
I thought that it has been the issue in the print layout as well, but I'm not sure anymore and I will check again when I'm back in the office. If it's not the issue on print layout - like you say - then I agree on your approach. Where should this default scale be defined in your opinion?
Thanks
Dave
David Signer
[david at opengis.ch](mailto:david at opengis.ch)
[+41 (0)78 766 13 03](tel:+41787661303)
[](http://www.opengis.ch)
> On Tue, 19 Feb 2019 at 19:03, David Signer wrote:
> > Hi there
> > I'm struggling with the following issue https://issues.qgis.org/issues/21309 summarized like this:
> > When using map units as symbol size and having a max value in mm, this value is always taken in the GetLegendGraphics request with QGIS Server, what leads to huge symbols there (same in legend of print layout).
> > I think it's not always needed to adapt the exact size to the legend.
> > So I see three approaches:
> > - Don't adapt the size to the legend at all
> > - Provide a configuration "Maximum size for legend"
> > - Provide a max size property for the server (does not solve it for print composer)
> > Where I would prefer the "Maximum size for legend" configuration.
> > What do you think?
> Isn't the underlying issue here that server generates the legend
> without any knowledge of map scale? (And presumably uses a scale of 0
> or some other huge scale, resulting in the symbols taking their
> maximum size)?
> If so, then i think the solution is:
> 1. Expose the choice of scale within the GetLegendGraphics call
> 2. Allow users to set a "default" legend scale for a particular
> project, and use this scale when generating the legend.
> Can you elaborate? The legend in print layout correctly follows the
> scale of the linked map item (and there's unit tests covering this).
> Nyall
> > Thanks
> > Dave
> > David Signer
> > david at opengis.ch
> > +41 (0)78 766 13 03
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190220/54ff3015/attachment-0001.html>
