[QGIS-Developer] Provide a max. legend size in case of map unit sized symbols
Nyall Dawson
nyall.dawson at gmail.com
Tue Feb 19 14:34:13 PST 2019
On Tue, 19 Feb 2019 at 19:03, David Signer <david at opengis.ch> wrote:
> Hi there
> I'm struggling with the following issue https://issues.qgis.org/issues/21309 summarized like this:
> When using map units as symbol size and having a max value in mm, this value is always taken in the GetLegendGraphics request with QGIS Server, what leads to huge symbols there (same in legend of print layout).
> I think it's not always needed to adapt the exact size to the legend.
> So I see three approaches:
> - Don't adapt the size to the legend at all
> - Provide a configuration "Maximum size for legend"
> - Provide a max size property for the server (does not solve it for print composer)
> Where I would prefer the "Maximum size for legend" configuration.
> What do you think?
Isn't the underlying issue here that server generates the legend
without any knowledge of map scale? (And presumably uses a scale of 0
or some other huge scale, resulting in the symbols taking their
maximum size)?
If so, then i think the solution is:
1. Expose the choice of scale within the GetLegendGraphics call
2. Allow users to set a "default" legend scale for a particular
project, and use this scale when generating the legend.
Can you elaborate? The legend in print layout correctly follows the
scale of the linked map item (and there's unit tests covering this).
Nyall
> Thanks
> Dave
> David Signer
> david at opengis.ch
> +41 (0)78 766 13 03
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
