[QGIS-Developer] Changes to @atlas_feature?
Spencer Gardner
spencergardner at gmail.com
Wed Feb 27 13:21:51 PST 2019
Looking deeper, I realized even unfiltered attribute tables aren't showing
up for me. I can show column names, but no rows are displayed. Can anyone
else confirm?
On Wed, Feb 27, 2019 at 1:17 PM Spencer Gardner <spencergardner at gmail.com>
wrote:
> I'm still seeing issues. From what I can tell, the Expression generator
> appears to be correctly reading the @atlas_feature variable now, and in
> fact most references in the Reports are working correctly. However, my
> attribute tables are still empty on the Reports page. I'll file a bug
> report to see if we can get to the bottom of it.
> On Mon, Feb 11, 2019 at 8:47 PM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> On Tue, 12 Feb 2019 at 09:59, Spencer Gardner <spencergardner at gmail.com>
>> wrote:
>> > I have a map document set up with a report that filters an attribute
>> table based on an attribute in the layers used for filtering (i.e. the
>> "atlas" layer for lack of a better Reports-oriented term). In 3.4.2 I could
>> use the @atlas_feature variable to grab the attribute I needed, but I've
>> discovered this doesn't work in 3.4.4. Was there a change to the handling
>> of @atlas_feature between the two versions? If so, I'll file a bug report.
>> Otherwise, I'm at a loss as to what's going on.
>> That's an unfortunate bug in 3.4.4 - it's fixed for next weeks 3.4.5
>> release.
>> Nyall
>> > Thanks!
>> > Spencer
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190227/a340949f/attachment.html>
