[QGIS-Developer] Changes to @atlas_feature?
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Feb 27 23:25:51 PST 2019
Seems this bugfix has not been backported to 3.4.x yet (see pull request
https://github.com/qgis/QGIS/pull/9306).
Regards,
Marco
Am 27.02.19 um 22:21 schrieb Spencer Gardner:
> Looking deeper, I realized even unfiltered attribute tables aren't
> showing up for me. I can show column names, but no rows are displayed.
> Can anyone else confirm?
> On Wed, Feb 27, 2019 at 1:17 PM Spencer Gardner
> <spencergardner at gmail.com <mailto:spencergardner at gmail.com>> wrote:
>     I'm still seeing issues. From what I can tell, the Expression
>     generator appears to be correctly reading the @atlas_feature
>     variable now, and in fact most references in the Reports are
>     working correctly. However, my attribute tables are still empty on
>     the Reports page. I'll file a bug report to see if we can get to
>     the bottom of it.
>     On Mon, Feb 11, 2019 at 8:47 PM Nyall Dawson
>     <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>> wrote:
>         On Tue, 12 Feb 2019 at 09:59, Spencer Gardner
>         wrote:
>         > I have a map document set up with a report that filters an
>         attribute table based on an attribute in the layers used for
>         filtering (i.e. the "atlas" layer for lack of a better
>         Reports-oriented term). In 3.4.2 I could use the
>         @atlas_feature variable to grab the attribute I needed, but
>         I've discovered this doesn't work in 3.4.4. Was there a change
>         to the handling of @atlas_feature between the two versions? If
>         so, I'll file a bug report. Otherwise, I'm at a loss as to
>         what's going on.
>         That's an unfortunate bug in 3.4.4 - it's fixed for next weeks
>         3.4.5 release.
>         Nyall
>         > Thanks!
>         > Spencer
>         > _______________________________________________
>         > QGIS-Developer mailing list
>         > QGIS-Developer at lists.osgeo.org
>         <mailto:QGIS-Developer at lists.osgeo.org>
>         > List info:
>         https://lists.osgeo.org/mailman/listinfo/qgis-developer
>         > Unsubscribe:
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190228/c3422a95/attachment.html>
More information about the QGIS-Developer mailing list
