[QGIS-Developer] confirmation message after plugin upload
Alessandro Cristofori compatt84 at gmail.com
Thu Jan 17 01:15:48 PST 2019
Yes, a plugin with the same name already exists but it is not for version 3
and above (the name does not appear in the plugins list). I asked the
developer of the original plugin if I could use the same name, he agreed so
I did use it. The plugin contains indeed improvements respect to the
current version, so it made sense to call it the same. As it does not
appear in the official QGIS 3 repository I thought it should not have been
a problem. I will try to think about another name and upload it again.
Thanks
AC
Il giorno gio 17 gen 2019 alle ore 07:00 Alessandro Pasotti <
apasotti at gmail.com> ha scritto:
> Did you check if a plugin with the same name already exists?
> On Wed, Jan 16, 2019 at 11:21 PM Alessandro Cristofori <
> compatt84 at gmail.com> wrote:
>> Hello,
>> I have just uploaded to the QGIS plugin repository my first plug-in.
>> After having read all the documentation, provided a LICENSE a README and
>> having filled the metadata.txt file I zipped it and uploaded via the upload
>> page.
>> As a confirmation I get a white page that says "You cannot modify this
>> plugin". White page with just a just this message on top.
>> Does this mean that the upload was successful or not? And if not, what
>> could I do to upload a plugin correctly?
>> Thanks
>> Alessandro
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190117/2ca6b64b/attachment.html>
More information about the QGIS-Developer mailing list
