[QGIS-Developer] confirmation message after plugin upload
Paolo Cavallini
cavallini at faunalia.it
Thu Jan 17 01:30:58 PST 2019
it would be better to keep both versions in the same repo, if possible,
to avoid duplication and confusion among users.
Thanks.
On 17/01/19 10:15, Alessandro Cristofori wrote:
> Yes, a plugin with the same name already exists but it is not for
> version 3 and above (the name does not appear in the plugins list). I
> asked the developer of the original plugin if I could use the same name,
> he agreed so I did use it. The plugin contains indeed improvements
> respect to the current version, so it made sense to call it the same. As
> it does not appear in the official QGIS 3 repository I thought it should
> not have been a problem. I will try to think about another name and
> upload it again. Thanks
> AC
> Il giorno gio 17 gen 2019 alle ore 07:00 Alessandro Pasotti
> <apasotti at gmail.com <mailto:apasotti at gmail.com>> ha scritto:
> Did you check if a plugin with the same name already exists?
> On Wed, Jan 16, 2019 at 11:21 PM Alessandro Cristofori
> <compatt84 at gmail.com <mailto:compatt84 at gmail.com>> wrote:
> Hello,
> I have just uploaded to the QGIS plugin repository my first
> plug-in.
> After having read all the documentation, provided a LICENSE a
> README and having filled the metadata.txt file I zipped it and
> uploaded via the upload page.
> As a confirmation I get a white page that says "You cannot
> modify this plugin". White page with just a just this message on
> top.
> Does this mean that the upload was successful or not? And if
> not, what could I do to upload a plugin correctly?
> Thanks
> Alessandro
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
