[QGIS-Developer] connecting to QgsNetworkAccessManagers signals
Alessandro Pasotti
apasotti at gmail.com
Sat Jan 19 08:22:51 PST 2019
Nice plugin though!
Try this: https://termbin.com/3y60
On Sat, Jan 19, 2019 at 3:51 PM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 1/18/19 10:56 PM, Nyall Dawson wrote:
> > On Fri, 18 Jan 2019 at 21:19, Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
> >> On 1/18/19 12:13 PM, Alessandro Pasotti wrote:
> >>> I didn't look at the code but maybe it's because the NAM instance is
> >>> per-thread and WMS/WFS downloaders run within threads.
> >> Yeah, that is what I'm afraid of...
> >> I just do QgsNetworkAccessManager.instance() which get's it from current
> >> thread.
> >> And (from what I understand) most providers do not keep an handle to
> >> some NAM :-(
> >> There is no way to QgsNetworkAccessManager what instances are running in
> >> different threads?
> > It'd need to be a change made in the core code -- the signals from the
> > background threads would need to be "bubbled up" to the main thread
> > instance of the manager.
> Meaning (?), that wherever now a signal of the nam
> (NetworkAccessManager) is connected to some local method, it is also to
> be connected to the nam of the parent/application thread?
> I had a look into some providers, but do not understand where this
> connection between signals is to be made?
> Is it in the application main thread when you create some
> downloader-class that you add some extra 'connect'-calls?
> Or is it in the downloader-class that you can fetch the
> parent/application thread and then get the nam-instance from there and
> do the connection?
> Or should I not even try :-)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190119/8c88165e/attachment-0001.html>
