[QGIS-Developer] $scale vs @map_scale - QGIS v2 vs v3
Andreas Neumann
a.neumann at carto.net
Mon Jan 21 05:05:24 PST 2019
Hi Matthias,
Yes - I will do the find and replace in text editor.
But what is the reason that behaviour was changed?
Is there a technical reason to do this change?
For the users such changes are always a bit annoying of course ... but
if there is a technical reason (and I understand why this was changed),
then I feel a bit better when I do all this find and replace work ;-)
Andreas
On 2019-01-21 13:57, Matthias Kuhn wrote:
> Hi Andreas,
> I think the easiest approach is to search and replace in the project files.
> Expressions are in so many places in QGIS, it's close to impossible to write code that finds them all and updates.
> Bests
> Matthias
> On 1/21/19 1:52 PM, Andreas Neumann wrote:
>> Hi,
>> When migrating our version 2 to version 3 projects, most of our symbology needs revision, because our data-defined properties used a lot the "$scale" variable.
>> What is the exact reason that $scale fails in version 3 and had been replaced by @map_scale?
>> Is there really no upgrade path for this? We have many, many projects, and almost all of them need to be upgraded in version 3 to use "@map_scale" instead of "$scale".
>> Thanks for your reply,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Matthias Kuhn
> matthias at opengis.ch
> +41 (0)76 435 67 63 [1]
> [2]
Links:
[1] tel:+41764356763
[2] http://www.opengis.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190121/d7f4d9fe/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190121/d7f4d9fe/attachment.png>
