[QGIS-Developer] $scale vs @map_scale - QGIS v2 vs v3
Nyall Dawson
nyall.dawson at gmail.com
Mon Jan 21 18:14:33 PST 2019
On Tue, 22 Jan 2019 at 08:53, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Mon, 21 Jan 2019 at 22:52, Andreas Neumann <a.neumann at carto.net> wrote:
> > Hi,
> > When migrating our version 2 to version 3 projects, most of our symbology needs revision, because our data-defined properties used a lot the "$scale" variable.
> > What is the exact reason that $scale fails in version 3 and had been replaced by @map_scale?
> > Is there really no upgrade path for this? We have many, many projects, and almost all of them need to be upgraded in version 3 to use "@map_scale" instead of "$scale".
> There is a technical reason behind this, but there's also no technical
> reason we couldn't make $scale silently "alias" to @map_scale. My
> original thinking was that I wanted to strip out some of these older
> expression formats, and 3.0 was a good opportunity to do this. But I'm
> happy to reverse this decision.
> PR incoming.
https://github.com/qgis/QGIS/pull/8933
Nyall
