[QGIS-Developer] 2 questions on saving rasters in 3.4
Andreas Neumann a.neumann at carto.net
Fri Jan 25 01:10:05 PST 2019
Hi Nyall,
>> My data is originally coming from an ESRI ascii grid. It had been many hundred tiles of ascii grids which I merged into a single big GEOTIFF file. The original data had up to 3 digits after the decimal point for the terrain height (mm accuracy) per cell. After import to the Geotiff the data has now many more (useless) digits after the comma, because the number of the digits in the geotiff is now defined by the float32 data type I chose. When I export that data back to ESRI ascii grid I get 15! digits after the decimal point. I would like to round it back to 2 digits after the decimal point (cm accuracy).
> I might be missing something, but it sounds like this change in
> precision has happened at the conversion to geotiff stage, not the
> "clip raster by extent" stage?
I would assume the same. The useless (excess) prescision change happened
when converting the asc files to GeoTIFF files. But is there a way to
define a "precision" when creating a GeoTIFF other than choosing between
Byte, UInt16, Int16, UInt32, Int32, Float32, Float64, CInt16, CInt32,
CFloat32 and CFloat64 ?
So if I want to store a meter-based terrain model with 2 digits after
the decimal point I would have to choose Float32 which already results
in a large number of digits behind the decimal point (useless ones,
usually).
So really I need to use the DECIMAL_PRECISION creation option (co) when
exporting the asc ESRI Ascii-Grid file. This was proposed by Luke
Pinnter in cc and works very well.
Perhaps for the future, it could be an idea to store some
DECIMAL_PRECISION meta-information in the header of the Geotiff file.
Then the various tools that work on rasters in QGIS could know that they
should never ever output more digits after the decimal point than what
was defined with this parameter - This parameter could be used in all
raster operations we do in QGIS (e.g. when querying raster values, when
exporting data, zonal statistics, etc.)
Does that sound like a useful way forward to store such a
meta-information parameter in the header of the GeoTIFF files in a
future version of QGIS? If there is a "standard" way for setting a
precision parameter in GeoTIFF files, we should use that, if not, we can
invent something aligned with the "GDAL" way of doing things, such as
the "DECIMAL_PRECISION" parameter.
Thanks and greetings,
Andreas
More information about the QGIS-Developer mailing list
