[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Matthias Kuhn
matthias at opengis.ch
Fri Jul 5 01:45:49 PDT 2019
FYI,
An upstream bug has been closed on Qt side
https://bugreports.qt.io/browse/QTBUG-57672
I didn't find a matching one on LLVM side so I opened one
https://bugs.llvm.org/show_bug.cgi?id=42515
Matthias
On 6/26/19 11:50 AM, Loïc Bartoletti wrote:
> Hi rainer,
> Le 26/06/2019 à 11:23, Rainer Hurling a écrit :
>>> - can you try with llvm 6 or 7 from ports (I think that FreeBSD 13
>>> have llvm 8 by default)?
>> Loïc, this seems to be the right approach. With llvm 8 and 7 the
>> build fails, with llvm 6 all builts fine!
>> As a fallback (workaround), I could enforce the port to use llvm 6,
>> until the real cause is found.
> You should fill an issue to our bugzilla. Maybe llvm or core dev can
> take a look at this bug? AFAIK, Ed found already an error (not
> reproduced?) in FreeBSD devel with newest llvm version.
>> The problem seems to be with
>> src/core/qgscoordinatereferencesystem_legacy.h and its long table,
>> handled via QMap. Obviously, newer llvm versions (7 and 8) are not
>> able to create the code correctly.
> I'll test with newer llvm version but on FreeBSD 12.
> It doesn't seem to affect Linux, since Docker is based on Ubuntu 19.04
> and clang 8 if I'm not mistaken. Nyall, Denis, can you confirm?
> Regards
> Loïc
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
