[QGIS-Developer] Locked layers and styles in layouts - where to see used layers?
DelazJ
delazj at gmail.com
Mon Jul 8 07:45:15 PDT 2019
See the last example at
https://docs.qgis.org/testing/en/docs/user_manual/print_composer/composer_items/composer_label.html#exploring-expressions-in-a-label-item
to create a list of used layers in a 'map 1' map item.
Hope that helps,
Harrissou
Le lun. 8 juil. 2019 à 16:31, magerlin <MAP at ramboll.dk> a écrit :
> I am going to reuse an old project file with 20 layouts which each are
> different based on what layers are locked in the layout.
> But now the background map source is going to be changed so I have to
> unlock
> layers in all 20 layouts to make them show the new background map.
> But then I will loose the information on what layers should be locked (ie.
> included) in each layout.
> Anywhere I can see what layers are included/locked in each layout?
> Final solution may be to open the project file in an XML editor - it must
> be
> stored there somewhere
> I should probably have used "map themes" but it is to late now......
> Regards Morten
> Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel
> Windows 7, 64bit
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190708/2e46f06f/attachment.html>
