[QGIS-Developer] Survey on If you use QGIS what do you like the most about it?
C Hamilton
adenaculture at gmail.com
Mon Jul 8 12:13:46 PDT 2019
I thought I would share with you some results of a survey I conducted
earlier this year. There were 86 responses. Most users were using 2.x
versions of the software, but some were using 3.x. Each person that
responded may of had one or more items. I consolidated the similar
responses so the number in front is the number of people that had the same
basic answer.
17 - Easy to use and conduct analysis when compared with ESRI products.
1 - Editing is easier than with ArcGIS
2.- Supports excellent customization.
1 - Easier work flow for editing and creating figures.
13 - Much faster than ESRI products.
3 - Crashes less often than ArcGIS.
4 - More stable than ESRI software.
6 - Performs better than ESRI Desktop.
1 - Causes less headaches than ESRI software.
1 - Has better functionality and more useful tools than ArcGIS.
1 - More responsive than ESRI products to mouse and keyboard commands.
4 - Can do anything ArcMap can.
1 - Handles displaying big data points better than ArcGIS.
11 - Software is free.
1 - Saves the office $$$.
4 - Freedom from license restrictions.
2 - Free to download and use at home.
5 - Open source
4 - Being open source makes it easy to work with others.
2 - Conforms to OGC standards.
10 - Can easily be extended with plugins.
2 - Extensive 3rd party integration such as GRASS, TauDEM, SAGA, LASTools,
and R
1 - Interesting addons not found in ArcGIS.
1 - Has great toolboxes.
10 - Works with hundreds of data formats.
2 - Produces a standards based GeoJSON file unlike ArcGIS that produces a
modified format.
5 - Provides the very best interaction and support for PostgreSQL/PostGIS
databases. ArcGIS does not work will with PostGIS.
2 - Better database integration.
1 - Can make PostGIS layers based on queries in QGIS.
4 - Full featured GIS application.
1 - 64 bit architecture.
2- Fast integrated GDAL/OGR library operations.
3 - Nice to have an integrated Python console.
1 - Easier to create a filter in QGIS than in ArcMap.
2 - Some QGIS tools work better than what ArcMap provides.
3 - Visualization tools are superior to ArcGIS including better rendering /
blending capabilities.
1 - Has unique geoprocessing capabilities.
1 - Easy to write script to automate tasks.
1 - Like the persistent layer properties window, which makes infinitely
more sense than endless pop-up clicking in Arc.
1 - Like how QGIS handles imagery stretching look-up tables.
1- Like draw pausing and cannot understand why ESRI can't get this right.
2 - Strong user community support.
1 - Can plot csv files onto a map and connect related tables of information.
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190708/9982678d/attachment.html>
