[QGIS-Developer] QGIS-Developer Digest, Vol 165, Issue 24
Stefan Steiger
Steiger at cor-management.ch
Thu Jul 11 08:09:52 PDT 2019
There's a docker file, if anybody wants to try PostgreSQL 12:
https://github.com/docker-library/postgres/blob/87b15b6c65ba985ac958e7b35ba787422113066e/12/Dockerfile
@giovanni:
It works if you're SuperUser :p
-----Ursprüngliche Nachricht-----
Von: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Giovanni Manghi
Gesendet: Donnerstag, 11. Juli 2019 13:19
An: qgis-developer at lists.osgeo.org
Betreff: Re: [QGIS-Developer] QGIS-Developer Digest, Vol 165, Issue 24
Hi all,
> Here is a quite interesting new feature in PostgreSQL 12:
> https://www.2ndquadrant.com/en/blog/generated-columns-in-postgresql-12
> It is similar to virtual columns in QGIS.
> I suspect that users will want to use that new column type. What does
> this mean for QGIS? I guess QGIS will have to detect this new column
> type in the future and mark it as "immutable". So other columns are
> read/write, but generated columns will be read only. Does QGIS already
> support a concept like this where some columns are read/write and
> others not
speaking about unsupported postgresql features it would also be very useful supporting correctly column permissions, the last time I checked (not recentli I admit) it didn't worked at all in QGIS.
cheers!
-- G --
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
