[QGIS-Developer] Changelog for 3.8! ARgh!
Matthias Kuhn matthias at opengis.ch
Mon Jul 15 22:29:08 PDT 2019
Hi Tim
On 6/23/19 8:37 PM, Tim Sutton wrote:
> Hi Matthias
>> On 21 Jun 2019, at 11:47, Matthias Kuhn <matthias at opengis.ch
>> <mailto:matthias at opengis.ch>> wrote:
>> Hi
>> On 6/21/19 9:03 AM, Tim Sutton wrote:
>>> Hi
>>>> On 21 Jun 2019, at 08:50, Matthias Kuhn <matthias at opengis.ch
>>>> Yes, I think it would make a lot of sense to integrate the
>>>> changelog creation directly with labels into pull requests.
>>>> Since projecta is also based on markdown this should all play
>>>> nicely together. And we could even add an (optional) #Changelog
>>>> section to the pull requests and some other tags to automatically
>>>> set funder etc. so one could already write the whole changelog
>>>> entry during the development cycle. That should easily pay back
>>>> with all the volunteer time that is saved during the already busy
>>>> run up time to release!
>>>> Resource wise, most the allocated time in the grant proposal is for
>>>> getting the service up and running and integrating with all the
>>>> notification hooks. Parsing the content and sending it to another
>>>> API should be pretty much straightforward. The main question would
>>>> rather be if creation of new versions can also be automated and how
>>>> to decide to which version a new feature should be sent (i.e. find
>>>> out the "current" version). The best match for this would probably
>>>> be to use github milestones. In the end I would say that this
>>>> should increase the offer by 20%.
>>>> Tim, is everything ready on your end for that?
>>> So yes we would be happy to pitch in to help here. Admire can help
>>> more immediately by getting this changelog ready and we can work
>>> with Anita (Hapsari) to get things in place to support PR githook
>>> thing-a-me-doodahs. (See my reply to OP)
>> Great! I started with the changelog, but it's not even close to
>> finished, so whatever Admire gets too on Monday will be appreciated.
>> And of course whatever others get to meanwhile!
>> Concerning the changelog, I think there are too possibilities:
>>   * Integrate it into the service we are going to set up if the grant
>> proposal is accepted. This will already have some logic builtin to
>> cover things like also reacting to labels added after the PR is
>> merged etc.
>>   * Bypass the grant proposal service and directly hook into the
>> github webhooks, which I think is what you propose.
> Can you share the link again to your proposal?
Sure,
After some fiddling I finally found the link to the proposals again.
https://docs.google.com/document/d/1VzgLJ-hy2GtcWrAy5geivhDDdXRGJUDcikCWUtXRe9k/edit#heading=h.cuzf1c5o2ciq
Basically the idea is to do pretty much the same thing as the GitHub
Backporting App (https://github.com/tibdex/backport#goal). The app will
listen to label changes and state (open/close) changes and open issues
on the docs repo accordingly, but could very well also call other REST
APIs upon such events. The result should be a fairly generic and open
source Github App, that can be installed on any repo and configured via
a yaml file inside the repo.
Best regards
Matthias
> Yes I was leaning towards a generic approach if possible, but let me
> read your proposal again and see how that fits in…
> Regards
> Tim
>> I think the main advantage of the first one would be that it could be
>> integrated in a single tool and since we would be working on it
>> already it would be less effort. The second one would add some value
>> to projecta if it can be used for other projects too.
>> I'm happy to step back if the second one is preferred.
>> Regards
>> Matthias
>>> Regards
>>> Tim
> *Tim Sutton*
> *Co-founder:*Kartoza
> *Ex Project chair:*QGIS.org <http://QGIS.org>
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:*timlinux on #qgis at freenode.net <http://freenode.net>
> I'd love to connect. Here's my calendar link
> <https://calendly.com/timlinux> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190716/be0f2f1d/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190716/be0f2f1d/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
