[QGIS-Developer] prj files not used when adding layer by drag and drop
magerlin
MAP at ramboll.dk
Tue Jul 16 04:06:06 PDT 2019
I have a shapefile with projection defined in a prj file.
If I open it using the menu it is shown as expected with no questions about
projection.
If I drag and drop the shp file onto the canvas I am asked to choose the
projection (from scratch - prj file apparently not read).
The actual shapefile has no qpr file
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.8.0 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
