[QGIS-Developer] DBManager save querys only saves selected code - Bug or Feature?
Nyall Dawson
nyall.dawson at gmail.com
Sun Jul 21 16:13:03 PDT 2019
On Sun, 21 Jul 2019 at 18:29, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi,
> Is there any other software with this behavior to "save only selected"? Or a use case where this is desirable?
> From top of my mind I can't find anything and I think all our other editors always save the full text, regardless of selection.
+1 to that. If a user really needs to save only a selected portion I
think it's fine to require them to copy that part to a text editor and
save from there. I'd rather not overload the UI with two options "save
all"/"save selected bit only", it's just overkill.
Nyall
> Regards
> Matthias
> On 7/21/19 10:19 AM, Alexandre Neto wrote:
> I agree that it can be a feature, but needs to be more explicit to the user.
> My problem is that I was creating several instructions and running them one by one. Then, in the end, I wanted to save everything and didn't realize that there was a selection.
> Documentation alone won't be enough IMHO. So, maybe a check box with "Save selected only?
> Anyway, thanks for making saving available.
> Alex
> A Sáb, 20/07/2019, 18:27, Loïc Bartoletti <lbartoletti at tuxfamily.org> escreveu:
>> Hi Alexandre,
>> It's my bad, I used _getSqlQuery insted of self.editSql.text().
>> For me a feature must be documented and for this one the user must have the choice between the full text or the selected part. So it's a bug or I add this option and the doc.
>> Regards,
>> Loïc
>> Le 20/07/2019 à 17:04, Alexandre Neto a écrit :
>> Hi,
>> I had some frustrations with the DB Manager save query functionality. At some point I finally understood that, if there is some selected code, only that part is saved.
>> To me it's weird, because when you save, the rest of the code is maintained in the SQL editor, and the name of the query is showned in the topo.
>> But, when I turn of my project and open it again, surprise surprise, only the selected part is in the Query.
>> Bug or feature?
>> Alex Neto
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
