[QGIS-Developer] cdash issues?
Nyall Dawson
nyall.dawson at gmail.com
Sun Jul 21 16:14:12 PDT 2019
On Sun, 21 Jul 2019 at 09:55, Alexis R.L. <alroyliz0 at gmail.com> wrote:
> Greetings,
> I'm trying to check the image generated by my tests and I noticed that the cdash log was quite empty. I also noticed that the provided tinyurl link at the end of the build lead to a 500 error.
> I'm not sure what is going on recently with cdash or if the move away from cdash is intended.
> Does anyone know what might be going on or is it only on my end?
It was moved recently to https://cdash.orfeo-toolbox.org/index.php?project=QGIS
The link at the bottom of Travis results is still broken so you need
to manually go to dash to fetch results.
Nyall
