[QGIS-Developer] QgsProcessingAlgorithm: no output layer when cancelled
Nyall Dawson nyall.dawson at gmail.com
Mon Jul 22 16:10:13 PDT 2019
On Mon, 22 Jul 2019 at 17:41, Nils Nolde <nilsnolde at gmail.com> wrote:
> Hola,
> running into 2 notorious problems with the ORS Tools plugin:
> 1. QgsProcessingAlgorithm, where it doesn't return the features which
> were processed until the user presses Cancel. More elaborate on SE:
> https://gis.stackexchange.com/questions/328913/pyqgis-qgsprocessingalgorithm-no-output-layer-when-cancelled
That's by design, intended to avoid users getting misleading partial
results from a canceled algorithm.
> 2. Another, more subtle, behavior when someone uses the batch processing
> algorithms for ORS Tools plugin like so:
> - save result as .shp or .gpkg instead of memory layer
> - user exceeds our minutely query limit (usually 40 queries/minute),
> i.e. errors are printed, but internally NetworkAccessManager is just
> sleeping until the minute is over and the limit is lifted
> - when all is done, the resulting layer is empty. However, when using
> memory layers instead, the results are available.
Sorry, no clues as to why this is the case...
Nyall
More information about the QGIS-Developer mailing list
