[QGIS-Developer] Any ways to make the browser show files on network?
Nyall Dawson
nyall.dawson at gmail.com
Tue Jul 23 04:35:17 PDT 2019
On Tue, 23 Jul 2019 at 21:24, magerlin <MAP at ramboll.dk> wrote:
> Where I work somebody decided to use sharepoint as our document handling
> system - I will save you for my opinion on that!
> But it means that typically my GIS layers are stored at places like:
> \\files\Projects\11000382XX\1100038233\GIS\Layers\
> And I se no way of getting to there in the QGIS browser window?
> And as the "Change data source" for a layer is based on the browser I cannot
> use this feature.
> I can map the network drive but with many people working on the same data I
> need to assure that they will map it the same way as the mapping will be
> stored in the project file.
Currently the only way to do this is by adding a favorite for the
path. Creating a favorite allows you to manually enter a path.
Nyall
> Regards Morten
> Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.8.0 in parallel
> Windows 7, 64bit
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
