[QGIS-Developer] How can I find the tickets that I reported?
Sandro Santilli
strk at kbt.io
Wed Jun 5 03:57:24 PDT 2019
On Wed, Jun 05, 2019 at 10:26:21AM +0200, Alessandro Pasotti wrote:
> On Wed, Jun 5, 2019 at 10:13 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> > On Wed, 5 Jun 2019 at 18:11, Sandro Santilli <strk at kbt.io> wrote:
> > > On Wed, Jun 05, 2019 at 09:48:59AM +0200, Andreas Neumann wrote:
> > > > But everything will be easier when we move from Github to Gitlab ;-)
> > > Except learning curve will need to be taken once again...
> > And the many 10's of 1000s of $$ it will cost to migrate all the CI
> > and integration scripts. The values of those should never be
> > understated.
> IMO now that's dockerized it should not be that hard to move to another CI
> infrastructure (not that I'm proposing that now).
For the record, https://dronie.osgeo.org (login with OSGeo credentials)
is already docker-based, and is currently used by both GEOS and PostGIS.
See https://git.osgeo.org/gitea/postgis/postgis/commits/branch/svn-trunk
and https://git.osgeo.org/gitea/geos/geos/commits/branch/master for
examples (those green-or-red tiny icons near each commit).
NOTE that an externally hosted instance of Drone (the open source software
used for https://dronie.osgeo.org) can be pointed to github.com for
getting used to it. See examples of that here:
https://github.com/postgis/postgis/pull/403
In the case above, the _same_ CI configuration is read by both the
OSGeo hosted instance (building PRs opened on https://git.osgeo.org)
_and_ by the externally hosted instance (building PRs opened on github)
--strk;
