[QGIS-Developer] GSoC QGIS 3D Improvement: Week 1 Report
Ismail Sunni
imajimatika at gmail.com
Wed Jun 5 23:27:58 PDT 2019
Hi Nyall
Just a thought -- did you try splitting this navigation widget off
> into it's own tool-style window? Maybe doing so and letting the window
> manager force it to sit above the 3d window would help.
We had a discussion about this and since the tool-style window will be on
top and the 3D map view is also on top, they will "fight". I tried a little
experiment with another tool window, and the result is the window is merged
in a tab style window.
> That giant
> amount of wasted space on the right is certainly a downer.
We also feel the same, but it seems for this GSoC project, that's the best
way I can go since we have time limitation. Hopefully, we can make it
better later.
Nice progress Ismail, keep up the great work!
Thanks, Nyall
Best regards.
On Mon, Jun 3, 2019 at 3:48 AM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Sat, 1 Jun 2019 at 23:57, Ismail Sunni <imajimatika at gmail.com> wrote:
> > Dear QGIS developers
> > Here is my 1st-week report for my GSoC Project. You can also check it on
> the wiki page [3][4]. Comments and suggestions are welcome :)
> > Best regards
> > GSoC 3D Improvement Week 1 Report
> > Period: 27 May 2019 - 2 June 2019
> > Report
> > 1. What did I complete this week?
> > * Trying to implement floating widget above Q3DWindow --> Not possible
> > * Decide with the mentors to implement it as a normal widget next to
> the Q3DWindow
> > * Implement the navigation widget and add the functionality (zoom
> in/out, tilt up/down, rotating)
> manager force it to sit above the 3d window would help. That giant
> > * Add the button to show and hide the widget (still using random icon)
> > 2. What am I going to achieve for next week?
> > * Make the rotating button sync with the map (currently it can rotate
> the map, but when the map rotate it doesn't move)
> > * Create better icons for the buttons and make the rotation widget
> looks
> > * Testing
> > * Make a pull request to merge the works
> > 3. Is there any blocking issue?
> > * Previously yes, with the Q3DWindow, after discussing with mentors,
> we will go to the normal widget. Another option: using QtQuick (needs to
> add dependencies), render the control manually (too much work)
> > 4. Code
> > * For the initial works, my mentors asked me to work on my small
> project [1] so that it is faster to developer
> > * For the QGIS implementation [2]
> > 5. Misc
> > * We have daily text stand up in a slack channel
> Nyall
Ismail Sunni
ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190606/69997e9f/attachment-0001.html>
