[QGIS-Developer] Pb QGIS 2.18 / pyuic4
Vincent Damoy
vincent.damoy at espaces-naturels.fr
Thu Jun 6 02:52:24 PDT 2019
Hello,
I've got problems with an old development environment, that I use to
maintain my plugins.
I want to compile a QGIS plugin that I created myself.
I'm working with QGIS 2.18 and I've got an error with pyuic4 and a UI file :
My version of pyuic4_ : 4.12.1
*The message error**: *
Makefile:52: recipe for target 'ui_bdtravaux_sortie.py' failed
make: *** [ui_bdtravaux_sortie.py] Error 1
And *the **debug text*: (pyuic4 -d ui_bdtravaux_sortie.ui)
# -*- coding: utf-8 -*-
# Form implementation generated from reading ui file
'ui_bdtravaux_sortie.ui'
# Created by: PyQt4 UI code generator 4.12.1
# WARNING! All changes made in this file will be lost!
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/port_v2/invoke.py",
line 34, in invoke exit_status = driver.invoke()
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/driver.py", line 59,
in invoke
self._generate()
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/driver.py", line 98,
in _generate
self._opts.resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/__init__.py", line
173, in compileUi
winfo = compiler.UICompiler().compileUi(uifile, pyfile,
from_imports, resource_suffix)
File
"/usr/lib/python2.7/dist-packages/PyQt4/uic/Compiler/compiler.py", line
55, in __init__
CompilerCreatorPolicy())
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/uiparser.py", line
183, in __init__
self.factory = QObjectCreator(creatorPolicy)
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/objcreator.py", line
94, in __init__
modinfo = plugin_locals["moduleInformation"]()
File "<string>", line 52, in moduleInformation
File "/usr/lib/python2.7/dist-packages/qgis/__init__.py", line 26, in
<module>
from qgis.PyQt import QtCore
File "/usr/lib/python2.7/dist-packages/qgis/PyQt/QtCore.py", line 28,
in <module>
sip.setapi(api, 2)
ValueError: API 'QDate' has already been set to version 1
I've use my plugin for years, but I have recently changed my computer
(and reinstalled all my development environment), and the error appeared.
I wrote to pyuic4 support, and this is their answer :
/"//This is a qgis bug. They change the API version which is unsupported
in production code."/
Is there a way to bypass this bug with these pyuuic4 and QGIS versions?
Thanks for advance
Vincent Damoy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190606/6560810c/attachment.html>
