[QGIS-Developer] translate plugin gui and log messages
Roberta Fagandini
robifagandini at gmail.com
Thu Jun 20 08:51:57 PDT 2019
Hi all,
following Jonas suggestion to use pylupdate5 script, I finally found a
possible solution.
I have created a .bat file with the following lines (probably are obvious
for most of the dev community ;-)):
@echo off
call "C:\OSGeo4W64\bin\o4w_env.bat"
call "C:\OSGeo4W64\bin\qt5_env.bat"
call "C:\OSGeo4W64\bin\py3_env.bat"
@echo on
pylupdate5 myPlugin.pro
The .bat file creates the .ts file correctly and then I modified and
released it with Qt Linguist.
Hope this helps!
Roberta
Il giorno gio 20 giu 2019 alle ore 10:16 DelazJ <delazj at gmail.com> ha
scritto:
> Hi
>> On Thu, Jun 20, 2019 at 9:11 AM matteo <matteo.ghetta at gmail.com> wrote:
>>> > Hi Matteo,
>>> > thank you for the help, your solution works fine in linux. Do you know
>>> > if something similar exists for Windows?
>>> make transup and make transcompile just call bash scripts..... not sure
>>> what the workaround could be in Windows. Doesn't Windows have a kind of
>>> linux bash integrated?
>>> Yes, I think. Cygwin [0] and alike are designed for that.
> But I think the osgeo4w.bat file under the osgeo4w install folder should
> be enough. From what I can see, I can run bash commands inside (at least it
> recognize "make" commands that the usual Windows cmd.exe ignores).
> [0] https://www.cygwin.com/
> Regards,
> Harrissou
> Matteo
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Ismail Sunni
>> ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190620/e471b987/attachment.html>
