[QGIS-Developer] translate plugin gui and log messages
C Hamilton
adenaculture at gmail.com
Fri Jun 21 07:36:51 PDT 2019
This seemed to work, but I have a question about translation. I first
created the english .ts file. I assume that someone then does a translation
of that file, but I notice in the XML that it has it tied to a line number.
What happens when I make a change to the code and the line number changes?
How is this all managed?
On Thu, Jun 20, 2019 at 11:52 AM Roberta Fagandini <robifagandini at gmail.com>
wrote:
> Hi all,
> following Jonas suggestion to use pylupdate5 script, I finally found a
> possible solution.
> I have created a .bat file with the following lines (probably are obvious
> for most of the dev community ;-)):
> @echo off
> call "C:\OSGeo4W64\bin\o4w_env.bat"
> call "C:\OSGeo4W64\bin\qt5_env.bat"
> call "C:\OSGeo4W64\bin\py3_env.bat"
> @echo on
> pylupdate5 myPlugin.pro
> The .bat file creates the .ts file correctly and then I modified and
> released it with Qt Linguist.
> Hope this helps!
> Roberta
> Il giorno gio 20 giu 2019 alle ore 10:16 DelazJ <delazj at gmail.com> ha
> scritto:
>> Hi
>>> On Thu, Jun 20, 2019 at 9:11 AM matteo <matteo.ghetta at gmail.com> wrote:
>>>> > Hi Matteo,
>>>> > thank you for the help, your solution works fine in linux. Do you know
>>>> > if something similar exists for Windows?
>>>> make transup and make transcompile just call bash scripts..... not sure
>>>> what the workaround could be in Windows. Doesn't Windows have a kind of
>>>> linux bash integrated?
>>>> Yes, I think. Cygwin [0] and alike are designed for that.
>> But I think the osgeo4w.bat file under the osgeo4w install folder should
>> be enough. From what I can see, I can run bash commands inside (at least it
>> recognize "make" commands that the usual Windows cmd.exe ignores).
>> [0] https://www.cygwin.com/
>> Regards,
>> Harrissou
>> Matteo
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Ismail Sunni
>>> ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190621/a2bb8c9d/attachment.html>
